Morning.
I made a custom chart in solarwinds as part of a contact for a customer requires us to check and received data from their image scanning environment. Ideally the chart should look something like this:
After seeing there was no edit button, I made a call to solarwinds who said that a hotfix would resolve my problem...which didn't resolve my problem.
Their other suggesting was to update our environment to hopefully resolve this issue. Which we can't do as our old environment is unlicenced/unlicensed. So after some messing about on the Unix box (weirdos having Unix on there) I kinda worked my way around with the help of the solarwinds SAM team to make another custom chart pointing to the correct pointers.
When I produce the report I get the following:
Again, having a chat with the SAM team, they have told me that this is a 'bug' within SAM 6.3 and that..dun dun dunnn SAM 6.4 does not fix it. It might fix it in a much later patch, but for now, it's not working. Which I can't exactly leave.
From what solarwinds are telling me I need to merge some SQL rows to hopefully make it work.
If anyone has a way of making it work of advice or guidance, that would be wonderful as this is contract dependant.
