We are required to turn on bit locker on our Windows systems. I was looking for a report that might say yes or no if bit locker is enabled. I couldn't find one. Is there a report or a custom report I could make to search for this?
Matt
It looks like you can report on Bitlocker from Registry settings, so for the Patch Manager piece you'll want to set up an Inventory template using the Registry keys:
Collect file, folder, or Registry information - SolarWinds Worldwide, LLC. Help and Support
To help you get started with WHICH registry keys, I found the following:
Is Bitlocker Encryption status set anywhere in the Registry?
BitLocker Group Policy settings (Windows 10) | Microsoft Docs
Sawyer Family: BitLocker Registry Keys
Once you are pulling an Inventory for the correct Keys you can run a standard report or create a new one:
Administration and Reporting -> Reporting -> Configuration Management Reports -> Computer (Registry Information) and the Basic Registry Information report.
Thanks I'll give it a try.
