Hello,
I've got the SDK installed and working great.
Also have the powershell stuff working in my tests...
...then I went to test the REST API with Postman and for the life of me I cannot get this thing to connect or get any data it seems.
At first if I try postman with enable SSL certs on, it tells me that a self-signed cert was found and errors out however, if I turn off that requirement in postman... I get a warning about it and everything I try I get a 404 error???
https:// FQDN:17778/Orion/InformationService/v3/Json/
