In some cases you may want to populate custom properties automatically and one way to do that is using an alert action.
In this example we will be adding the MAC Address to a custom property named _MacAddress with the actual MAC address
There are many other use cases such as when adding nodes in large numbers using discovery, nodes that are added by engineers that are not familiar to Orion, etc.
First thing you will need to do is set up an alert and whatever trigger conditions you want to use for the alert. This is used to pinpoint the nodes you want the custom property to apply to
Next set up an Alert Action to Change Custom Property. In this case we are using a custom property called _MacAddress
On this screen, select the custom property you would like to populate
The Custom Property Value can be simple text, or you can use variables to get a value from the database. In this case we are using a value from a SWQL query to retrieve the MAC Address.
You can use any value from the database using this method
${N=SWQL;M=SELECT TOP 1 N.Interfaces.PhysicalAddress from orion.Nodes N Where Caption like '${N=SwisEntity;M=Caption}'}Once you have that info filled out complete creating the alert.
Items to note. Each time the alert runs it will update hundreds or thousands of custom properties, but there is a timeout that may keep it from completing all of your nodes. If this happens simply disable and reenable the alert and it will continue updating again until it reaches the timeout limit. You may need to do this a few times but eventually all of the nodes will get updated.
