First: is still only Cisco APs that are recognised by the WiFi Heatmaps process?
Second: once a heatmap is "generated" does it auto-update to show poor/better coverage as APs come and go on/offline? Or are they a static "best case" scenario until you re-generate the heatmap?
Third: I presume that irrespective of whether the answer to 2 is auto or manual, the heatmap generation is pretty much instant?
Fourth: how accurate have folks found these heatmaps? Do you find they are more accurate the more 'samples' you can add?
Fifth: (and last): is there an Orion Maps equivalent of this facility or is that another one that hasn't yet been ... (how shall we say this?) ... progressed?
Bottom Line: if you don't use this aspect of the SolarWinds tool, what do you use for heatmaps?
