I was looking for a way to schedule the muting of alerting on individual nodes between specific times every day. I couldn't find a way to achieve this on a single node without having to create multiple alerts for specific instances. I have several servers which generate alerts daily during virus scans, or backups. I found a sample on github from the SDK and have edited to achieve what I want, but I don't understand why this is not an option as default, I can only assume I am missing something obvious and the ability is there, I just missed it? Would rather have an out-of-the-box solution rather than this. I see the option to do it on a specific day, but you cant simply pick a time instead.
If not, then feel free to use the below.
node,timefrom,timeto
SERVER01,16:30:00,17:30:00
SERVER02,16:30:00,17:30:00
The script needs to be run on a schedule at the start of each day as the script imports the above from CSV format and then proceeds to build a hash table formatting the date using the current day as its date to schedule and adds on the time from the CSV.
Import-Module SwisPowerShell
$OrionServer = 'localhost'
$Username = ''
$Password = ''
$swis = Connect-Swis -Hostname $OrionServer -Username $Username -Password $Password
#Get Nodes and schedule from csv file and convert date
$Nodes = Import-Csv 'C:\Scripts\nodes-mute-schedule.csv'
$Today = Get-Date -Format dd/MM/yyyy
$Schedule = Foreach ($Node in $Nodes){
$Table = [PsCustomObject]@{
Node = $Node.node
entityUris = $entityUris = Get-SwisData $swis "SELECT Uri FROM Orion.Nodes WHERE Caption IN @captions" @{captions=($node.node)}
TimeFrom = ($Today +" "+ $Node.timefrom -as [DateTime] )
TimeTo = ($Today +" "+ $Node.timeto -as [DateTime] )
$Table
# Suppress alerts for one or more entities
Foreach ($object in $Schedule){
$entityUris = $object.entityUris
$entityUris = @( $entityUris |% {[string]$_} )
Invoke-SwisVerb $swis Orion.AlertSuppression SuppressAlerts @($entityUris, $object.Timefrom.AddHours(1), $object.Timeto.AddHours(1)) | Out-Null
# List alert suppressions
Get-SwisData $swis "SELECT ID, EntityUri, SuppressFrom, SuppressUntil FROM Orion.AlertSuppression"
