Another malware discovered called SUNSPOT in Orion Build.
Can someone from solarwinds confirm whether the version 2020.2.1 HF2 is affected by this ? Any actions need to take?
Alankar
No, the name "SUNSPOT" refers to the specific malware that was used in the initial targeted attack against SolarWinds. "SUNSPOT" itself was not found in the code, but was used as the means of compromising the code. You can read a detailed analysis directly from Crowdstrike's blog: SUNSPOT Malware: A Technical Analysis | CrowdStrike.
The key points that they made, quoted directly:
Hope that info helps!
Thanks @sturdyerde for information .
There are many articles showing it's a new malware discovered by crowdstrike.
https://cps-vo.org/node/72790
https://www.bleepingcomputer.com/news/security/new-sunspot-malware-found-while-investigating-solarwinds-hack/
