We have NPM, NTA, IPAM, NCM, UDT, VM Manager. When running vulnerability scans against our Orion server we see old versions of Java installed in the solarwinds root folder. They don't show up in the install programs list but there in the solarwinds root. Can I get rid of them? If not can they be updated somehow to current versions? If not, how do you remove them when they don't show up in the installed programs?
Path : C:\Program Files (x86)\SolarWinds\Orion\OpenJDK\13\bin\java.exe Installed version : 1.13.0_00 Latest versions : 1.8.0_271 / 1.11.0_9 / 1.15.0_1 Support dates : 2020-04-01 (end of life) Path : C:\Program Files (x86)\SolarWinds\Orion\OpenJDK\14\bin\java.exe Installed version : 1.14.0_02 Latest versions : 1.8.0_271 / 1.11.0_9 / 1.15.0_1 Support dates : 2020-10-01 (end of life)
Path : C:\Program Files (x86)\SolarWinds\Orion\OpenJDK\13\bin\java.exe Installed version : 1.13.0_00 Fixed version : 1.7.0_241 / 1.8.0_231 / 1.11.0_5 / 1.13.0_1
The following vulnerable instance of Java is installed on theremote host : Path : C:\Program Files (x86)\SolarWinds\Orion\OpenJDK\13\bin\java.exe Installed version : 1.13.0_00 Fixed version : 1.7.0_261 / 1.8.0_251 / 1.11.0_7 / 1.14.0_1
Path : C:\Program Files (x86)\SolarWinds\Orion\OpenJDK\13\bin\java.exe Installed version : 1.13.0_00 Fixed version : 1.7.0_251 / 1.8.0_241 / 1.11.0_6 / 1.13.0_2
