Is there any way someone from SolarWinds can provide corresponding build numbers for the affected version descriptions that would match what we can look up in the installer logs? That's the easiest way I can think of to go back through the history of updates and find exactly which version we were running between March and now, but I haven't found any table that shows something like this:
| NPM 2019.4 HF2 | 119.4.8959.0 |
| Orion Core 2019.4 HF4 | 119.4.20161.5220 |
That's just one example of a best guess I came up with from reading through the installer logs, but having the build numbers for the affected modules would be very helpful to identify if we were actually running the affected version.
Thank you!
