NOTE: This is a quick recreation of an existing document, if you are logged into Thwack, you will be able to see the visual color codes here https://thwack.solarwinds.com/t5/Group-Archive/Brocade-SNMPv3-Configuration-Example/gpm-p/522047
PURPOSE: Simplified guide for Brocade FastIron Ethernet Switch SNMPv3 Configuration
Reference: Brocade SNMPv3 Overview
This guide is to provide a technical breakdown of the configuration so that you have a better understanding for setting up SNMPv3. Configuration Example at the bottom.
Notes for the Guide:
Username: TestSNMPv3User
Password: P@$$w0rd
View Name: TestSNMPv3View
Group Name: TestSNMPv3Group
- Create the View
- If you see %Bad OID, then Internet does not exist, use ISO (if exists), or 1.3.6
- Included MIB Family is included in the view
- Excluded MIB Family is excluded from the view
- Create the Group
- Example Command: SNMP-Server group TestSNMPv3Group v3 priv Read TestSNMPv3View Notify TestSNMPv3View
- Everything under here currently verifying
- v1: Group using the v1 security model
- v2c: Group using the v2c security model
- v3: Group using the User security model (SNMPv3)
- Auth: Group using the authNoPriv Security Model
- Noauth: Group using the noAuthNoPriv Security Model
- Priv: Group using the authPriv Security Model
- Access: Specify an access-list associated with this group
- Context: Specify a context to associate these views for the group
- Notify: Specify a notify view for the Group – Send a syslog every time a view is touched
- Read: Specify a read view for the group
- Write: Specify a write view for the group
- Create the User (usually do not see the user in Show Run/Show Start configurations)
- Example Command: SNMP-Server user TestSNMPv3User TestNMPv3Group v3 Auth AES P@$$w0rd priv P@$$w0rd
- Remote: Specify a remote SNMP entity to which the user belongs
- Auth: Authentication parameters for the user
- Encrypted: Specifying passwords as MD5 or SHA digests
- MD5: Use HMAC MD5 algorithm for authentication
- SHA: Use HMAC SHA1 algorithm for authentication
- 3DES: Use 168 bit 3DES algorithm for encryption
- AES: Use AES 128, 192, or 256 bit algorithm for encryption
- DES: Use 56 but DES algorithm for encryption
- Send to Destination Host:
- Example Command: SNMP-Server host 10.10.1.161 version 3 privacy TestSNMPv3User
Note: 10.10.1.161 is the Solarwinds server. If the Server is not in the list, then you will not be able to add the Device
Example Configuration
SNMP-Server group TestSNMPv3Group v3 priv Read all Notify all
For more information, please see Brocade's Documentation:
http://www.brocade.com/downloads/documents/html_product_manuals/FI_ICX6650_07500_AG/FI_Security_SNMP...
