Does xp_cmdshell need to be enabled on the SQL server for Solarwinds NPM? Is there any issues that will occur if it is disabled?
It is being pointed out as a security risk so I would like to disable it if possible.
Thanks for you help in advance!
Have you had a response on this?
Thanks.
If the SQL server is remote then the answer is No, it's fine to disable it.
