How do I create KPI modern dashboard for VPN connected user total
We just upgraded to Orion 2020.2. I am looking at the "My Dashboards" feature and want to create the KPI box with all my VPN routers reporting their connected users. My failure I am having is creating the SWQL query to display the data. Would anyone have the layout in the graphical query builder? I am not well versed in SQL or SWQL queries. Any help is much appreciated
Top Replies
  • Can you go into more detail on what type of VPNs you're using? If you search in the left column for "vpn" within swql studio it'll show you just the fields pertaining to VPN.
  • We are using Cisco anyconnect. What I am trying to achieve is a KPI widget with all the VPN sessions with the sum of all ASA connections. We currently have the anyconnect spread across 5 different ASA's.
  •  are you looking for something as simple as the widget below to display a count of users connected?
    If the above is what you are looking to achieve then the below SWQL should give you the desired results.
    SELECT
    count ([data].[RemoteAccessSessions].[UserName]) AS [Number]
    FROM orion.asa.node AS data
    where [data].[RemoteAccessSessions].[EncryptionAlgorithm] = 1
    and ([data].[RemoteAccessSessions].[NodeId] = XXX or [data].[RemoteAccessSessions].[NodeId] = XXX)
    and [data].[RemoteAccessSessions].[DisconnectedTime] is null
    Where the XXX is the Solarwinds NodeID of your ASA Devices, in our situation we only have 2 of then, but if you have 5 then you will have to expand this line to cover all 5 devices.
  • This is exactly what I am looking for. Thanks so much for the help.
  • Does anyone have any tips on getting this type of information when using FTD2110 instead of ASA? I've been bruising my forehead hitting my desk looking for an answer
  • Slightly modified and the count is exactly what you see in the 'Remote Access VPN' tab
    SELECT
    where [data].[RemoteAccessSessions].[SessionStatus] = 1
  • If you're using a custom UDP poller then the SWQL query would be as follows:
    SELECT CurrentValue
    FROM Orion.NPM.CustomPollerAssignmentOnNode
    Where NodeID = 'X' AND DisplayName LIKE 'XXXXXXX'
    X = SolarWinds Node ID
    XXXXXXX = Name of the poller. It is usually something like crasNumSessions
    Hope this helps.
  • Does anyone know how I take that query and add the totals for 2 VPN UDP values so I just have 1 total?
    SELECT CurrentValue
    Where NodeID = '1434' AND DisplayName LIKE 'VPNCurrentUsers' OR NodeID = '2042' AND DisplayName LIKE 'VPNCurrentUsers'
  • Hi, not very good at SWQL queries but I believe a sum function is required here. Have you tried below? We have two VPN gateways and this query gives me one result.
    SELECT
