Hello all,
I have a question that should be simple but apparently isn't...
I'm attempting to monitor bandwidth utilization at remote sites using NPM, however I keep getting incorrect information. A number of our smaller remote sites only have a single T-1 circuit, but SolarWinds still treats them as 100MB since the monitored interface has a throughput of 100Mb. I can't monitor the actual device that has the T-1 circuit directly connected (long story), so I want to get accurate data from the closest interface to that device (i.e. another router or switch). As a test, I manually set one of those interfaces to a custom Bandwidth of 1.544 Mb/s (Transmit and Receive) but it still doesn't show correctly on my network utilization map, or when I run performance metric tests.
I need to collect this information in order to justify bandwidth increases at most of my remote sites, so I need the data to be as accurate as possible. I do also have NetFlow running on my routers and switches that support it, that is sending data to SolarWinds as well.
