Hey Guys,
Im trying to install evaluation copy of NPM 12.3 with default database and it was success, but while performing configuration wizard, ending up with "No valid package combination was found for current system"
Looking for some help if Im missing anything.
Log Content:
2020-03-25 23:32:51,880 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,881 [11] DEBUG DependencyAnalyzer - Orion.Apollo.Recommendations [1.5.0.5019,]
2020-03-25 23:32:51,882 [11] DEBUG DependencyAnalyzer - 1.5.0.5019 [OK]
2020-03-25 23:32:51,882 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,883 [11] DEBUG DependencyAnalyzer - Orion.Apollo.VIM.CapacityPlanning [8.3.0.8122,]
2020-03-25 23:32:51,884 [11] DEBUG DependencyAnalyzer - 8.3.0.8122 [OK]
2020-03-25 23:32:51,885 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,886 [11] DEBUG DependencyAnalyzer - Orion.CloudMonitoring [2.0.2.1244,]
2020-03-25 23:32:51,886 [11] DEBUG DependencyAnalyzer - 2.0.2.1244 [OK]
2020-03-25 23:32:51,887 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,888 [11] DEBUG DependencyAnalyzer - SolarWinds.CortexPlugin.Orion.Cman [1.0.0.148,]
2020-03-25 23:32:51,889 [11] DEBUG DependencyAnalyzer - 1.0.0.148 [OK]
2020-03-25 23:32:51,890 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,890 [11] DEBUG DependencyAnalyzer - Orion.CMAN [1.0.0.1159,]
2020-03-25 23:32:51,891 [11] DEBUG DependencyAnalyzer - 1.0.0.1159 [OK]
2020-03-25 23:32:51,892 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,893 [11] DEBUG DependencyAnalyzer - SolarWinds.Orion.CloudMonitoring.VIM [2.0.2.486,]
2020-03-25 23:32:51,893 [11] DEBUG DependencyAnalyzer - 2.0.2.486 [OK]
2020-03-25 23:32:51,894 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,895 [11] DEBUG DependencyAnalyzer - Orion.AddNode [1.1.0.306,]
2020-03-25 23:32:51,896 [11] DEBUG DependencyAnalyzer - 1.1.0.306 [OK]
2020-03-25 23:32:51,897 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,897 [11] DEBUG DependencyAnalyzer - Orion.HardwareHealth [8.4.0.655,]
2020-03-25 23:32:51,898 [11] DEBUG DependencyAnalyzer - 8.3.0.531 [FAIL]
2020-03-25 23:32:51,899 [11] DEBUG DependencyAnalyzer - 8.4.0.655 [OK]
2020-03-25 23:32:51,900 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,901 [11] DEBUG DependencyAnalyzer - Orion.SSO [1.0.0.68,]
2020-03-25 23:32:51,902 [11] DEBUG DependencyAnalyzer - 1.0.0.68 [OK]
2020-03-25 23:32:51,902 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,903 [11] DEBUG DependencyAnalyzer - Orion.DeviceContext [7.8.0.167,]
2020-03-25 23:32:51,904 [11] DEBUG DependencyAnalyzer - 7.8.0.167 [OK]
2020-03-25 23:32:51,905 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,905 [11] DEBUG DependencyAnalyzer - Orion.NCMShared [7.8.0.519,]
2020-03-25 23:32:51,906 [11] DEBUG DependencyAnalyzer - 7.8.0.519 [OK]
2020-03-25 23:32:51,907 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,908 [11] DEBUG DependencyAnalyzer - Orion.Apollo.NCM [7.8.0.1507,]
2020-03-25 23:32:51,908 [11] DEBUG DependencyAnalyzer - 7.8.0.1507 [OK]
2020-03-25 23:32:51,909 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,910 [11] DEBUG DependencyAnalyzer - Orion.Licensing [1.3.0.2242,]
2020-03-25 23:32:51,911 [11] DEBUG DependencyAnalyzer - 1.3.0.2242 [OK]
2020-03-25 23:32:51,911 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,912 [11] DEBUG DependencyAnalyzer - Orion.CliClient [7.8,)
2020-03-25 23:32:51,913 [11] DEBUG DependencyAnalyzer - 7.8.0.416 [OK]
2020-03-25 23:32:51,914 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,915 [11] DEBUG DependencyAnalyzer - Orion.NodeManagement [1.1.0.16,]
2020-03-25 23:32:51,916 [11] DEBUG DependencyAnalyzer - 1.1.0.16 [OK]
2020-03-25 23:32:51,916 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,917 [11] DEBUG DependencyAnalyzer - Orion.Search [1.8.1.2002,]
2020-03-25 23:32:51,918 [11] DEBUG DependencyAnalyzer - 1.8.0.379 [FAIL]
2020-03-25 23:32:51,919 [11] DEBUG DependencyAnalyzer - 1.8.1.2002 [OK]
2020-03-25 23:32:51,919 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,920 [11] DEBUG DependencyAnalyzer - Orion.UI.Components [1.8.1.2006,]
2020-03-25 23:32:51,921 [11] DEBUG DependencyAnalyzer - 1.8.0.990 [FAIL]
2020-03-25 23:32:51,922 [11] DEBUG DependencyAnalyzer - 1.8.1.2006 [OK]
2020-03-25 23:32:51,922 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,923 [11] DEBUG DependencyAnalyzer - Orion.Widgets [1.8.1.2009,]
2020-03-25 23:32:51,924 [11] DEBUG DependencyAnalyzer - 1.8.0.1417 [FAIL]
2020-03-25 23:32:51,925 [11] DEBUG DependencyAnalyzer - 1.8.1.2009 [OK]
2020-03-25 23:32:51,925 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-25 23:32:51,926 [11] DEBUG DependencyAnalyzer - Orion.AgentManagement [2.0.0.592,]
2020-03-25 23:32:51,927 [11] WARN DependencyAnalyzer - No packages of type Orion.AgentManagement found!!!
2020-03-25 23:32:51,928 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.AgentManagement [2.0.0.592,]
2020-03-25 23:32:51,929 [11] DEBUG DependencyAnalyzer - Orion.RecommendationEngine [1.2.0.211,]
2020-03-25 23:32:51,930 [11] WARN DependencyAnalyzer - No packages of type Orion.RecommendationEngine found!!!
2020-03-25 23:32:51,931 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.RecommendationEngine [1.2.0.211,]
2020-03-25 23:32:51,931 [11] DEBUG DependencyAnalyzer - Orion.ESI [1.2.0.314,]
2020-03-25 23:32:51,932 [11] WARN DependencyAnalyzer - No packages of type Orion.ESI found!!!
2020-03-25 23:32:51,933 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.ESI [1.2.0.314,]
2020-03-25 23:32:51,934 [11] DEBUG DependencyAnalyzer - Orion.SSH [1.0.1.325,]
2020-03-25 23:32:51,935 [11] WARN DependencyAnalyzer - No packages of type Orion.SSH found!!!
2020-03-25 23:32:51,935 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.SSH [1.0.1.325,]
2020-03-25 23:32:51,936 [11] DEBUG DependencyAnalyzer - Orion.Apollo.PerfStack [2.2.0.679,]
2020-03-25 23:32:51,937 [11] WARN DependencyAnalyzer - No packages of type Orion.Apollo.PerfStack found!!!
2020-03-25 23:32:51,938 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Apollo.PerfStack [2.2.0.679,]
2020-03-25 23:32:51,938 [11] DEBUG DependencyAnalyzer - Orion.CortexIntegration [2.0.0.2120,]
2020-03-25 23:32:51,939 [11] WARN DependencyAnalyzer - No packages of type Orion.CortexIntegration found!!!
2020-03-25 23:32:51,940 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.CortexIntegration [2.0.0.2120,]
2020-03-25 23:32:51,941 [11] DEBUG DependencyAnalyzer - SolarWinds.CortexPlugin.Orion.Volumes [2.0.0.254,]
2020-03-25 23:32:51,942 [11] WARN DependencyAnalyzer - No packages of type SolarWinds.CortexPlugin.Orion.Volumes found!!!
2020-03-25 23:32:51,942 [11] ERROR DependencyAnalyzer - No packages are matching constraint SolarWinds.CortexPlugin.Orion.Volumes [2.0.0.254,]
2020-03-25 23:32:51,943 [11] DEBUG DependencyAnalyzer - SolarWinds.CortexPlugin.Orion.Nodes [2.0.0.891,]
2020-03-25 23:32:51,944 [11] WARN DependencyAnalyzer - No packages of type SolarWinds.CortexPlugin.Orion.Nodes found!!!
2020-03-25 23:32:51,945 [11] ERROR DependencyAnalyzer - No packages are matching constraint SolarWinds.CortexPlugin.Orion.Nodes [2.0.0.891,]
2020-03-25 23:32:51,946 [11] DEBUG DependencyAnalyzer - Orion.Apollo.NetworkAtlas [1.0.0.0,]
2020-03-25 23:32:51,947 [11] WARN DependencyAnalyzer - No packages of type Orion.Apollo.NetworkAtlas found!!!
2020-03-25 23:32:51,947 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Apollo.NetworkAtlas [1.0.0.0,]
2020-03-25 23:32:51,948 [11] DEBUG DependencyAnalyzer - Orion.Topology [2018.2.0.0,]
2020-03-25 23:32:51,949 [11] WARN DependencyAnalyzer - No packages of type Orion.Topology found!!!
2020-03-25 23:32:51,950 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Topology [2018.2.0.0,]
2020-03-25 23:32:51,950 [11] DEBUG DependencyAnalyzer - Orion.Maps [1.0.0.0,]
2020-03-25 23:32:51,951 [11] WARN DependencyAnalyzer - No packages of type Orion.Maps found!!!
2020-03-25 23:32:51,952 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Maps [1.0.0.0,]
2020-03-25 23:32:51,953 [11] INFO DependencyAnalyzer - Looking for a valid package combination using method: ORToolsResolutionStrategy
2020-03-25 23:32:52,156 [11] WARN DependencyAnalyzer - Failed to found a suitable package combination using method: ORToolsResolutionStrategy
2020-03-25 23:32:52,157 [11] INFO DependencyAnalyzer - Looking for a valid package combination using method: BasicDependencyResolutionStrategy
2020-03-25 23:32:52,161 [11] INFO BasicDependencyResolutionStrategy - Evaluating all possible combination of packages for current system according to defined roots.
2020-03-25 23:32:52,201 [11] DEBUG BasicDependencyResolutionStrategy - Found 0 valid walks.
2020-03-25 23:32:52,202 [11] INFO BasicDependencyResolutionStrategy - Looking for best package combination.
2020-03-25 23:32:52,206 [11] DEBUG BasicPackageSetSelector - Searching for best package ...
2020-03-25 23:32:52,209 [11] DEBUG BasicPackageSetSelector - Number of sets: 0
2020-03-25 23:32:52,210 [11] DEBUG BasicPackageSetSelector - Removing sets where are packages without sources
2020-03-25 23:32:52,216 [11] DEBUG BasicPackageSetSelector - Number of sets: 0
2020-03-25 23:32:52,217 [11] WARN BasicDependencyResolutionStrategy - No valid solution found
2020-03-25 23:32:52,218 [11] WARN DependencyAnalyzer - Failed to found a suitable package combination using method: BasicDependencyResolutionStrategy
2020-03-25 23:32:52,219 [11] WARN DependencyAnalyzer - Failed to found a suitable package combination using all available methods.
2020-03-25 23:32:52,220 [11] ERROR PackageManager - Cannot find no valid combination for current system.
2020-03-25 23:32:52,222 [11] ERROR ConfigurationProgressScene - Exception while configuring plugins.
System.Exception: No valid package combination was found for current system.
at SolarWinds.Packaging.Core.PackageManager.UpdateSystemInternal(UpdateSystemContext updateSystemContext, Boolean checkChangesOnly)
at SolarWinds.ConfigurationWizard.Common.Packaging.PackagingExecutor.UpdateSystem(IHostInfo hostInfo)
at SolarWinds.ConfigurationWizard.Host.Presentation.CommonConfiguration.ConfigurationProgressScene.DoConfigInThreadUnsafe_DeployPackages(IOrionConfigHost host, PackagingExecutor packaging)
at SolarWinds.ConfigurationWizard.Host.Presentation.CommonConfiguration.ConfigurationProgressScene.DoConfigInThreadUnsafe(IOrionConfigHost host)
at SolarWinds.ConfigurationWizard.Host.Presentation.CommonConfiguration.ConfigurationProgressScene.DoConfigInThread()
2020-03-25 23:32:52,230 [1] INFO OipClient - Tracking event: ConfigurationWizard - ConfigurationProgressScene - UpdateFailureText: • • No valid package combination was found for current system.
- False - 0
