Hi Team,
I am new to solarwinds , can any one explain me how to supress the alerts in npm 11.5.2 version.
Hi kondaveeti11,
Here's a document explaining how alerts function, which should help you with alert suppression too: Understanding Orion Advanced Alerts
Hi Maria,
Thanks for the update but in NPM 11.5.2 I cant see advanced alert manager , everything managed by web console itself. If I search advanced alert manager it is redirecting to web console only.
This might help:
NPM Core Training Part 6: Alerts - YouTube
While you definitely should read up on the basics of alerting on Orion, to more specifically answer your question I would need to ask what you mean by suppressing alerts in Orion? Do you mean there are too many of the out-of-the-box alerts triggering and you want to reduce the amount of them, or are you asking how to suppress alerts in a specific circumstance? As far as using the actual alert suppression feature of Orion then I don't think that is an available feature since NPM 11.5, as I've not seen that option since they moved to the Web Alerting Engine. Prior to the move to the web alerts in 11.5 there was a feature of the Advanced Alert Manager where you could add suppression conditions, but under most circumstances they were not useful since they didn't really work the way you would expect. Instead, it was better to just put negative conditions in your Trigger/Reset conditions to filter out alerting on objects you didn't want.
