Hello to Every Body,
***Thanks alot for answer my questions and i like this forum because of this, i have solved many problems in Orion Solarwinds***
Now the question is that,
When i Execute report using Peak Recieve and Peak Transmit Fileds, then Orion Report Writer Execute it and give me required report well done!, but after that output i have to compare the Values between Peak Receive and Peak Transmit and in result maximum value put into 3rd column with name Peak Utilization using MAX formula in Excel Sheet
Above discussion mean 3rd column work totaly is customized and time consuming because i have more than 500 network nodes.
So, please help me regarding this like
Is there any query in SQL, that automatically pick Maximum value from Peak Receive and Peak Transmit Fileds and Put int 3rd Column like Peak Utilization
Please answer me to solve this problem.
i want to solve this my problem to save time and generate quicker reports
Thanks Alot again
