When you add a node you should have the option of adding a custom object name at that time. Currently if you use custom object names as we do, an extra step is added to creating every object and its a little silly.
Related to this is the challenge of monitoring DHCP nodes in NPM. You should not be limited to using the fully qualified name used to identify the new IP address of the node as the node name. There were some other technical issues with monitoring DHCP nodes in orion at all... Im not sure if that issue has ben resolved or not.
