Hi all,
i am seeing between 2 and 5 messages per second written to the SolarWinds.net log in computer management as follows. is anyone else seeing this? is it a problem i shoudl be worried about?
it was present before the upgrade to 9.5...
Event Type: Information
Event Source: AlertingEngine
Event Category: None
Event ID: 0
Date: 22/06/2009
Time: 11:49:52 am
User: N/A
Computer: BT3NPM
Description:
2009-06-22 11:49:52,181 [AlertCheckingThread] WARN Error - Error in UpdateRowsThatAreReset() -
System.Data.SqlClient.SqlException: Ambiguous column name 'NodeID'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at AlertingEngine.CheckAlert.UpdateRowsThatAreReset()
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
