Hi All,
Please share the best way to audit the logs of TACACS by solarwinds.
which module will be best to capture and audit purpose.
thanks
Hi Krishna,
I think the best way to audit the logs of a TACACS server would be the use of Security Event Manager (SEM).
Success Center - Integrate Cisco ACS Syslog reports with SolarWinds SEM
You should be able to get quite a few audit reports
Passed Authentication
RADIUS Accounting
TACACS+ Accounting
TACACS+ Administration
VoIP Accounting
Note SEM has a ready parser for Cisco ACS (if that is the TACACS server you are using.
Cheers
Thank you RaviK, let me check the all steps and process.
