All
my unix admin is having a problem getting net-snmp to work with orion....he sent me this very basic conf file and said i should be able to connect to it. he loaded a product called Up.Time and using their agent he was able to get this working....but orion can't connect to the snmp on the server. i know more than what he has configured needs done but i'm not sure what to tell him. net-snmp version is 5.7.2 ...any help would be greatly appreciated.
this is what he sent me:
# snmpd.conf
# - created by the snmpconf configuration program
# SECTION: Access Control Setup
# This section defines who is allowed to talk to your running
# snmp agent.
# rocommunity: a SNMPv1/SNMPv2c read-only access community name
# arguments: community [default|hostname|network/bits] [oid]
rocommunity public
# SECTION: Monitor Various Aspects of the Running Host
# The following check up on various aspects of a host.
# load: Check for unreasonable load average values.
# Watch the load average levels on the machine.
# load [1MAX=12.0] [5MAX=12.0] [15MAX=12.0]
# 1MAX: If the 1 minute load average is above this limit at query
# time, the errorFlag will be set.
# 5MAX: Similar, but for 5 min average.
# 15MAX: Similar, but for 15 min average.
# The results are reported in the laTable section of the UCD-SNMP-MIB tree
load 90 95 95
# SECTION: System Information Setup
# This section defines some of the information reported in
# the "system" mib group in the mibII tree.
# syslocation: The [typically physical] location of the system.
# Note that setting this value here means that when trying to
# perform an snmp SET operation to the sysLocation.0 variable will make
# the agent return the "notWritable" error code. IE, including
# this token in the snmpd.conf file will disable write access to
# the variable.
# arguments: location_string
syslocation B5
# syscontact: The contact information for the administrator
# perform an snmp SET operation to the sysContact.0 variable will make
# the variable.
# arguments: contact_string
