In some routers supported by a vendor, we have only RO credentials. I can't get NPM to work with only RO credentials. Is there a way to add a node with SNMP but only use RO credentials?
If you leave the read/write credentials blank, then Orion will not try to use them. Only populate the read-only credentials.
Regards,
Matthew Harvey
Loop1 Systems
