Where is the Network Atlas Administrator Guide on their website? They refer to it in all there documentation for NPM but it is nowhere to be found. Can anyone help me locate it, or does it not exist.
turbo79 et al.,
I've attached the latest guide. The update will post to the web as soon as possible.
Thank you for the notification,
Hi, rgalloni.
Here is a direct link to the latest version of the Network Atlas admin guide.
Network Atlas Admin Guide (html version)
I'm looking for the same thing. The link above no longer works. Anyone else have a link?
http://www.solarwinds.com/support/orion/docs/OrionNetworkAtlasAdminGuide.pdf
Tyler, I just updated the link. Sorry for breaking it earlier. Brandon's gives you the PDF. The link in my post gives you the HTML version.
That link takes you to the guide for version 1.4
Looks like the current version is 1.5.0.45
Is there an updated version of the NetworkAtlasAdminGuide?
For the next version, please add content about the menu options. not all of them are obvious - i.e. - Status & Links - what exactly is "Navigate" for?
