Hi Solarwinds,
We are currently in the process of raising a PO for the Solarwinds software and 2x servers from our local vendors. License is as follow for Solarwinds:
- Orion Network Performance Monitor SL2000
- NetFlow Traffic Analyzer Module for Orion NPM SL2000
- Orion Network Configuration Manager DL200
We will be using Windows 2003 Standard 64bit and SQL 2005 or 2008.
I would like to know what are Solarwinds recommendation for server spec base on the license number (possible upgrade to NPM/NTA SLX in the future) on both 1st server running Solarwinds Application (listed above) and 2nd SQL Server.
Maximum of 30 users will be viewing the Orion Web Console constantly (mostly internal but some number overseas) with minimum delay.
We have location throughout Asia, Japan, Europe and Middle East polling (100 location, 6 servers 1 interface per location, 2 routers 60 interfaces per location, 1 APC temp sensor per location). The Solarwinds server will be hosted in our Sydney Data Center.
Peter
