How can I set Thresholds for specific memory % on specific / older Cisco 3660 routers - warning 60 critical 70.
These are Older devices and I don't want to change the values for all the other devices. same goes for setting CPU values.
Mike L
Create a node custom property called cpu_threshold and then use the complex condition to compare the current CPU consumption to the custom property for that node.
Why not create an alert for those devices? Then you can have an email sent when it reaches 60% and 70%. I don't know of a way to change an individual node's thresholds though.
Hope this helps.
Chrystal Taylor
http://www.loop1systems.com
Thank You For your help.
I did create a report using Custom Prop titled TOPS , I was able to pull the report and have it e-mail to my team using report schedular
Right on! Glad to hear it. Make sure you tag a correct answer so folks can find it. Maybe also share your report definition in the content exchange for others to use?
- you earn points for posting in the Content Exchange and 5 points for each download your content receives. This can be a quick way to earn points to spend in the store (coming soon).
