I thought I'd check first to see if anyone has developed any custom UnDP pollers to monitor optical tranceivers from these Cisco MIBs and care to share them? Why reinvent the wheel?
CISCO-OPTICAL-IF-EXTN-MIB
DESCRIPTION "A MIB module containing extensions to the IF-MIB for optical
interfaces. This revision adds a new table coIfXcvrTable to
control transceivers (lasers and optical receivers)
at optoelectronic interfaces. It also defines three new
code points, ethernetPhy, esconPhy and gigabitPhy
for the coIfTypeExtn object.
CISCO-OPTICAL-MONITOR-MIB
DESCRIPTION "This MIB module defines objects to monitor optical
characteristics and set corresponding thresholds on the
optical interfaces in a network element.
CISCO-OPTICAL-MONITORING-MIB (This MIB is temporary and experimental.)
DESCRIPTION "This MIB module is used to monitor optical parameters
of a network element.This MIB deals with the operating
parameters of the optical layer. The optical layer is a
term that defines all the devices/systems that deal with
the conversion of data in it's electrical form to optical
form, transmission of the optical data, reception, and
finally re-conversion to electrical signals.
