Hi everyone
In order to create a chart for a temperature sensor I tried and customized different resource views but none of them gave my favorable result. In my last try, I add a "custom object resource" to the page and in its edit page I set these parameters:
Choose Object Type ----> Hardware Sensors
Select Object ------> a specific "temperature Sensor on Temperature on Overall Hardware Status" of a specific Node
Select Object Resource -----> Hardware Health Chart for Temperature
and finally clicked on submit button.
The result is shown as follows:
what's going on and what is the solution?
I should add that if I choose node for "Choose Object Type" and a specific node for "Select Object" then all temperature sensors for that specified node will be shown on the chart. But what I want is a chart for a single chosen temperature sensor.
