Hi
My Orion Eval server is about to run out of time, and i bougt a real license, but how do i enable my license? I can't find a option where it is possible to enter a license key.
Hi Michael,
After the installation, the Configuration wizard will start up automatically. You can choose to connect to the database you used during your evaluation - all of the devices etc that were added will be in here.
Cheers!
You will need to download your full version of Orion from your customer portal, and install it. During the install, you will be asked for your SW number and password, and some other details - if you have internet connectivity from your server the installation program will download your license automatically from our key server. Otherwise, you will need to click "Skip This", and use the details provided to generate the license key from your customer portal.
Cheers,
Hi Caroline.
What will happen with my current installation? Will i lose all my devices etc.? It's only for a temporary period of time i need to keep my installation alive. I will make a new installation some time in the new year.
Thanks a lot. I'll try that.
