Found the best way to export vector art from Adobe Illustrator to Map Maker
Colorize your object into 4 colors, green, red, yellow, grey.
Do a File > Export on each one and save it as .EMF and folow the naming of the scaleable objects already in map maker, name.emf, name-down.emf, name-up.emf, and name-warning.emf
Copy the 4 files to the "imported" directory solarwinds\orion\maps\netobjects
The file sizes will be really small, and they will be vector art, meaning you can resize it to ridicoulous dimentions and it still will not distort
