I have menu bars created but they donot show in the menu
Ah sorry, so the main menu tabs are created by each module have installed, so
Orion Platform = Home
NPM = Network
SAM = Application
DPA = Databases
You can’t create custom top level headers, all you can do is decide what options are presented below them.
You need to select which menu bar you get from your Account Settings. I’m not at a PC right now so can’t post a screenshot, but once you’ve created your custom menu bar you go into your Account Settings and scroll down just below the account limitations section and you choose which menu your given for Home as well as the additional modules.
I think i found the option but i don't see how can i add one here. It only gives the option to change.
Have you created the menu bars in the Customize Menu Bars setting? You should be able to customize the existing ones, or create new ones (at the bottom). Everything is drag and drop from the options on the left to the created menu bar on the right. Hope this helps.
-ChrystalT
If look at my previous screenshot there is a test22 menu bar that was created. I am able to chose this menubar from drop down.
What i am asking is how to additional tab/menu besides these default 4.
Double check that you haven't been logged out.
Can you please provide more detail about your issue such as screen shots, troubleshooting you have done, or what have done that may not give you the expected result.
