I am trying to find a way when I go into Node Details if there is a way to create a tab that has a image of the currently selected node. I know when I customize the Node Details page and add an Map with an image of the device, the same image shows up no matter what device I select. I want to limit the image to the selected node only. Each time I select a different node, the image changes based on the node I select.
