I've created a number of maps and want to assign each map to its specific group.
Is this possbile?
Bc when i click on the Group, it loads the generic "Group Details" page, which i dont want b/c when i customize that it does every group.
off top of my head, you could create a view per map (don't know if feasible for your environment), then use links to go to group you want.
might be able to do something with custom properties and macros to generate links....
I found that you could not filter out maps by an account limitation so you would have to create a view for each map that you want to have.
Did you ever find your answer? My networks maps update based on group. When I edit the map settings in my group, I have Select Network Map set to blank (at the top of the list) and the Map Name Format set to ${Name}. As long as I have the name of the map the same as my group name it applies the correct map to my group.
Please review this discussion - I believe it should help - Custom Map for Group Details Page
