This forum is created if you encountered an issue adding a vBrick DME 7500 as an SNMP Node (SNMPv3).
Testing the SNMPv3 upon adding it as a node fails.
Resolution:
-Gather SNMPWalk using the IP address of the vBrick device then check for the minimum OIDs required to add a device to Orion:
1.3.6.1.2.1.1.1 sysdescr
1.3.6.1.2.1.1.2 sysobjectid
1.3.6.1.2.1.1.3 sysuptime
Minimum OIDs to add a device as an SNMP node - SolarWinds Worldwide, LLC. Help and Support
It seems that the device uses different OID for sysdescr and sysobjectid which we requires for getting the node details.
