Is there a possibiltiy in Orion NPM 9.2 to add Tabular Device poller to the summary view page.
I know there is an option to add the Universal device poller to the summary view page
We allow these to be published to the Node Details page.
If you want to publish a tabular UnDP, here is a method to accomplish this if you want to show a tabular device poller on Network Summary page
I too am looking to do this - but not for a node (which is what I believe the suggestion would do) - but for the entire collection of that statistic in a tabular format.}Eg I have a poller that pulls all the Temps on a Cisco switch - but I can only display the temps on my summary page - I can't display the MAX level which I also pull down and display on each node - so having the temp is only partially helpful - is there any way to display the table for all my cisco on one page?
thanks
If you want to display multiple devices, another potential option is to create a report that displays the information you require for the devices and publish and display that report on the Summary page.
