NPM 12.4. Created some UnDP poller, and also created it corresponding Transformed Poller (I just divide the returned value by 10, no complex formula).
- Both Assigned to same Nodes
- Both Tested successfully under UnDP
- Both Enabled Checked
- Both have the same polling interval
Problem: The Transformed column in the Node Details Summary View remain empty, just the title, while the actual poller value is displayed.
I tried to delete all and recreate them again from scratch as suggested in the THWACH forum, but that did not help.
Any one came across this issue please ?
