Can anyone tell me which MIB and OID NPM uses to report In/Out Errors and Discards?
Jon
Hi Jon--
I did some research and found the attached info in an older support log. Let me know if it helps you. If not, I'll do some more digging.
M
Hey Jon--
FYI--as you can see, Brandon has provided the OIDs that are also in my doc in this thread. The doc does provide some additional info, which you may want to check out.
Thanks both, it was exactly what I was looking for.
