We have a few thousand nodes in Orion. Some of the site routers are being upgraded by telecom operators and the naming scheme has changed slightly. This is why we now have over 300 devices where the node name doesn't match the system name (SNMP name) anymore. Could someone provide me with a short SQL script that would change the node names to match the system names?
Some routers have several addresses that need to be monitored. By browsing this forum, I have gotten the impression that it is not possible to configure several addresses for nodes. Thus we will have to add the same routers with the secondary addresses to Orion. To avoid collecting redundant SNMP statistics, we'll name the additional routers with "-secondary" suffix (e.g. office-cityx-gw and office-cityx-gw-secondary) and enable only ping polling for the secondaries. Since the nationwide router upgrade project is still under way, it is likely that there will be more changes to the SNMP names in the near future. Thus I would appreciate a suggestion on how to modify the script so that it would check if the original node name has the "-secondary" suffix and it would append it to the new node name derived from the system name. This way I could run the script again in a half an year without losing the manually added "-secondary" suffixes.
Best regards,
Marko
