Hi All
We currently have 2 separate servers and 2 separate databases, one for IPAM and one for NPM/NCM.
I found out when I did the last upgrade that if you have everything on one server/database, you can access all of it from the one web interface instead of using 2 separate ones.
So my question is: I know that you can't easily merge 2 NPM instances together, but can you merge NPM and IPAM databases into one, or will I need to have one new database with all of them and re-create from scratch?
Paul
