i have discovered my devices manually with snmpv3 and they are running for weeks without prob...(npm9.1)
recently ive done the ff
- installed sp3
-when npm web console is accessed from a remote ws thru http, a pop up comes to install toolkit and was accepted..
after the above activity, i noticed that almost all my devices has changed its snmp config to default public. tried rediscover menu by right cliking device, edit node but failing..listing resources also not working
tried re-add the device and with the same old snmpv3, only then it works.
whats seems to have gone wrong
