Maintain a record of web console user actions for auditing purposes.
I haven't found a report or view yet.
Add the resource that shows you 'Audit Events' - as in Last XX Audit Events
Most of the reports that I've ever been successful with I've had to create them manually.
Thanks looked past the :Last XX quite a few times. If it don't work out I'll have to try and write a report.
Go to Message Center using an account that has full administrator permission. One of the check boxes will be "Audit" events. Check that (and un-check everything else) AND make sure you have your time range set the way you want. Then hit refresh.
That's the one!
You can go through the manage reports and search audit there you will found report . view that report..
