Hey,
I downloaded NPM test package from your server. Installed it, and cannot login into the Webconsole under http://localhost:8787.
It says: Login failure. Username and/or Password incorrect.
I searched inside this forums around - tried nearly every thing descriped here in the forum. Nothing was working.
My enviroment:
- Windows Server R2 german, SP2 and all up-to-date updates!
- .NET 1.1, 2.0 SP1, 3.0 SP1, 3.5 installed.
- IIS complete installed
- MS SQL Express 2005 (here I tested the release from Microsoft side - german, as well as the inside the Testpackage from you - engl. version).
- Installation of all software and OS as out-of-the-box - I made NO changes in folders/naming/rights/or others!!
As I said, I looked around inside this forum, and found several post with the same problem. For me it seems a major problem, but as well, it seems there is no support/fix regarding this. As I see this as a major feature, it may be the keypoint to purchase or not. Momentarily not!
The other modules are working quite well - only the Webconsole sucks...
I wasted around 2-3 days with tests, reinstallings and so one. I realy would be happy if anyone could give me a hint or 'way to work around', i doubt there is a solution with 'one mousclick'.
To the 'alway-open-ticket' question -where please?
I gave my credentials into your system to download the testpackage, but when going to support, i will be asked about customer id - got none, from where should I get this no. please?
w. best regards
