All,
Have a problem after loading V9.0sp1. When opening System manager it shows no nodes in the left handside node list. In the Web Interface everything is fine.
If you try to find, add, etc the system returns
Runtime error -214722163 (80040155) Method '~' of object '~' failed. If I click OK the System Manager closes
Also get a box coming up that an actio cannot be completed because the other application is busy. Switch to or Retry
Finally accessing System manager after choosing the poller takes an age.
Has anyone seen this before. Cannot seem to find any logs that can point me in the correct direction
Regards
Julian
