quote:Originally posted by hvitsI am trying to configure advanced alerts on several applications where I can be notified if the process has stopped or is no longer running. Here is what I have done so far:1. created alert to monitor notepad.exe2. Trigger condition set to monitor, server, application name is equal to notepad.exe. I have tried this with process name also3. Application status is equal to down, i have also tried running copies is equal to none.I do not get any alerts, i have opened multiple notepad.exe and closed and I do not get an alert generated. I receive all my other alerts, and smtp is working fine. I also tried messenger service, no good.Thanks
quote:Originally posted by hvitsJust looked at the alerting engine and it is not running, nor will it start. Any ideas?? Thanks
quote:Originally posted by dclecompte quote:Originally posted by hvitsJust looked at the alerting engine and it is not running, nor will it start. Any ideas?? Thanks
quote:Originally posted by dclecompteHaving .Net 1.1 and .Net 2.0 will not cause a problem.Does your Orion server have a connection to the internet? Do your other services start? --e.g., Syslog, TrapDo you see anything in the Application Event Log or the SolarWinds event log regarding the service crashing?Denny LeCompteSr. Product Manager, OrionSolarWinds
quote:Originally posted by aLTeReGo<snip>Some days it works GREAT and others it doesn't work at all. This has NOTHING to do with alert "trigger actions" as I do not have any defined since rebuilding my alert rules, a task that took me 14 hours and made no difference. Solarwinds see the node, interface or application down, but the Alerting engine doesn't seem to have any clue that this has happened. This would be a problem with the alert "trigger conditions". One day it works, the next it doesn't. The only thing I see in my eventviewer related to the alerting engine is..Event Type: InformationEvent Source: AlertingEngineEvent Category: NoneEvent ID: 0Date: 1/31/2007Time: 10:43:26 AMUser: N/AComputer: XXXXXXXXDescription:Exception in MainTask Loop Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.For more information, see Help and Support Center at go.microsoft.com/.../events.asp.Can you offer any suggestions?
any progress on duplicating Exception in MainTask Loop event log entry and the resolution? does disabling Netbios over TCP resolve the issue?
I'm having the same issue. Have you found a resolution?
Event Type: ErrorEvent Source: AlertingEngineEvent Category: NoneEvent ID: 0Date: 9/7/2007Time: 12:36:29 PMUser: N/AComputer: pollernameDescription:2007-09-07 12:36:29,702 [MainTaskThread] ERROR All - Exception in MainTask LoopIndex was outside the bounds of the array.
