How do you removed devices from UnDP? Also why does interfaces appear under PowerSupplySource (it seems that would be at the node level not interface)?
Thanks in advance.
You don't remove a device. You can navigate to a device in the tree in the ALL NODES pane (upper left). Go to the target device and drill down until you see a folder called "Pollers". Right-click on the target poller and select Unassign.
Or, right-click on the target poller under ALL DEFINED POLLERS and select Assign. Then you'll see the assign list and you can add or remove assignments as desired.
I followed your indication but you can only assign pollers massively, unassign is not possible, isn't it?
Yes, you can use the UnDP UI to unassign multiple pollers at once.
Can you tell me how, please?
