I know that the new Orion NPM supports Windows & SQL 2008. Will the Orion APM module now work on Windows & SQL 2008 as well assuming you are using the latest version of Orion NPM with it?
Thanks in advance for any response!
Yes, Windows 2008 and SQL Server 2008 are supported with all modules with NPM 9.5/NCM 5.5.
