I have a report that I would like to ask for some help in getting it to work the way it has in the past and hasnt since we applied the last upgrade.
SELECT TOP 10000 CONVERT(DateTime,
LTRIM(MONTH(DateTime)) + '/01/' + LTRIM(YEAR(DateTime)),
101) AS SummaryMonth,
Nodes.NodeID AS NodeID,
Nodes.VendorIcon AS Vendor_Icon,
Nodes.Caption AS NodeName,
Nodes.IP_Address AS IP_Address,
AVG(ResponseTime.Availability) AS AVERAGE_of_Availability,
Nodes.Vendor AS Vendor
FROM
Nodes INNER JOIN ResponseTime ON (Nodes.NodeID = ResponseTime.NodeID)
WHERE
( DateTime BETWEEN 40878 AND 40907 )
AND
(Nodes.MachineType = 'Cisco 3845' )
AND
(Convert(Char,DateTime,108) >= '06:00') AND
(Convert(Char,DateTime,108) <= '18:30')
My question is that at one time, my one 3745 router also showed up in this report and now doesnt. With my limited SQL knowledge (I can spell SQL), I havent been able to find a way to get the 3745 to also show up in this report along with the other 3845's. I know it has to be something simple. I have tried doing it myself using a OR command and the 3845 syntax changed to reflect the 3745 but all that did was thoroughly trash the layout of the report.
Ron
