Since upgrading to NPM 12.5 our nightly database maintenance is failing due to not being able to delete the JET*.TMP files from the \WINDOWS\TEMP folder due to the files being locked by the Trap / Syslog Services.
In the Database Maintenance log near the top, there is a setting that states that the 'Daily removal of JET files is set to TRUE'
Is there anyway to switch this setting off.
I have had a look at the Database-Maint.exe-config file and I cannot see anything within this that mentions this.
Nor have I found anything in the webconsole under polling settings etc that remotely looks like this.
Or other standalone instance of NPM doesn't have this issue, however it is still running NPM 12.1 for the time being.
So is this check something new as part of NPM 12.5 and how can I set it to false to enable the nightly database maintenance to not report as failed.
Regards
Duncan
