Hi Folks,
I've been doing a bit of reading about the new, long awaited, fully fledged multi-threaded polling engine in NPM 10.2. I'm yet to upgrade but am considering making the change soon and after reading this doc I have a couple of questions.
It is mentioned that the polling performance is now mostly based on the hardware capability of the polling server. Does the '8000 elements at a 10 minute interval' approximate limitation still apply, or does this now mean that with an SLX license the polling intervals can be decreased until the CPU and memory are close to being max'd out?
If I were to continue throwing resources at the polling server would that increase the potential of the server to manage a higher polling 'weight'? I know it mentions the maximum polling load for NPM jobs as 2600, is this a true value or is it just an example. If it is accurate, how does 2600 max weight translate into real world polling ability; can you give an example of what weight a cisco 4500 switch monitoring CPU, Mem and 20 ports would have?
How does 1 unit of weight compare with the old terminology of 'elements' is there any direct correlation?
Regards
Ciaran
