Dear All,
Am not a expert in SQL, so wanted your help in understanding how to manage the SQL log file. We have around 900 nodes in the Orion NPM and its been running fine since 3-4 months. Though the database size is around 470Mbps but the log file has gone beyond 40GB.
Kindly advice as to if this is OK or some error is causing such high log file & is there a way to compress this log files.
Thanks & Regards
Vinod Dhure.
