I am getting this error every 2 hours for the past 30 days. Any clue how to solve it or fix it?
Running 9.0 SP2
Do you have traps running on an additional poller?
Nope
do you have Orion and SQL on separate servers? (...i do)
if so, did you add anything new like Orion NetFlow module 30 days ago which maybe put extra traffic on your SQL server?
or perhaps did you put on SP2 about 30 days ago?
looking at my own log, i have just one of these same events in my Solarwinds Orion Event viewer log but it appears to have happened when the WUS updates was processing at my SQL server and appears to have caused the event with the SQL client from Orion.
is there a single process other than SQL on your server showing continuous cpu time usage, that is, the hours are counting higher and higher?
Server has been up for longer than 30 days and SP2 for sql has been on it since day 1 of the server coming up. These errors are coming from the orion server not my SQL server.
