Hello,
I have a requirement to use RRDTool w/ Solarwinds NPM stats (on a limited basis ie: few customers, based on custom property).
Basically it is a work-around until we can get our Customer Portal re-worked to utilize EOC or hooking into our IIS server.
has anyone attempted to pull stats from SW into MRTG or RRDTool or any external tool like this?
I was thinking of possibly just running a perl script to pull the stats via the API every hour to populate, or maybe to prevent overhead on the API engine to hit the SQL Server via ODBC instead.
Help!
Will
